Inleiding
If your MSI GS66 Stealth laptop (model 11UE-007) is having problems with distorted sound, no sound at all or sound loss of any kind from your speakers, this guide is here to help! Broken speakers are a frequent problem with this laptop and are an essential part of any laptop.
Broken speakers can be a result of many different reasons for example, dropping the laptop, water damage, the volume being maxed regularly or even something as small as debris. This guide will take a step-by-step process in the replacement of ths speakers in the MSI GS66 Stealth laptop.
Wat je nodig hebt
Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
Disconnect the speaker power using the tip of the spudger or fingernail to gently push on either side of the connector.
Één andere persoon heeft deze handleiding voltooid.
