Ga door naar hoofdinhoud
MSI GS63VR 6RF Stealth Pro WiFi Card Replacement
Wat je nodig hebt
  1. MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: stap 1, afbeelding 1 van 3 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: stap 1, afbeelding 2 van 3 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: stap 1, afbeelding 3 van 3
    • First, turn off the laptop and make sure it is unplugged from power to avoid injury.
    • Unscrew the 15 screws on the bottom panel of the computer using a Phillips #00 screwdriver.
    • Lift open the back cover with a plastic spudger.
    • Gently lift the back cover away from computer. Make sure nothing is attached.
    • Unplug the battery cable from the motherboard to prevent a ground fault.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro WiFi Card Replacement: stap 2, afbeelding 1 van 2 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the single screw from the Wifi card using a Phillips #00 screwdriver.
    • Apply upward pressure on the cables using a plastic tweezer.
    • Using the plastic tweezers, carefully grab and gently wiggle the Wifi card out of its socket.
    • Gently pull the card upward from the slot.
    • The Wi-Fi cables can be easily damaged when removing or replacing the connectors. Please take extra care when performing these tasks
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Nabil Ranjbar
276 Reputatie
2 handleidingen geschreven
3 opmerkingen
Is this a msata card or a m.2 card?
keith dragon - Antwoord
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
Bastien Allaoui - Antwoord
Hi there , the wifi cable (aux) its not connecting to the card , probaly I have bent it , what problem does it cause because right now I still can use the wifi, and most important thing , where can I buy it and how can change it ? Thanks
Adriano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 18
Altijd: 4,072
