Ga door naar hoofdinhoud
MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement
Wat je nodig hebt
  1. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Hard Drive: stap 1, afbeelding 1 van 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Hard Drive: stap 1, afbeelding 2 van 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Hard Drive: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Turn off the laptop before proceeding.
    • Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
    • Pry open the back cover with a plastic prying tool.
    • Unplug the battery cable from the motherboard to prevent a ground fault. Either use your hand or a pair of tweezers to unplug the battery cable.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 2, afbeelding 1 van 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 2, afbeelding 2 van 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 2, afbeelding 3 van 3
    • Disconnect the SATA cables from the motherboard using a plastic spudger.
    • Gently pull out the SATA cables out of the ports.
    • Grab the auburn color cable and lift up the hard drive. Slide out the hard drive while holding onto the cable.
    • Cables are fragile. Do not apply excessive force.
  3. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Battery: stap 3, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Phillips screwdriver to remove the 15 screws securing the back cover.
    • Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
    • Do not insert the opening too too far into the back edge (with "Stealth" written on it), or you may damage the power LED.
    • The back cover is secured with clips. Too much pressure from the spudger can break the clips, but some flex is not dangerous.
    • Remove the back cover.
  4. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery by carefully pulling its connector towards the battery.
    • Pull parallel to the battery, not straight up.
  5. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 5, afbeelding 1 van 2 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 5, afbeelding 2 van 2
    • The battery is attached to the laptop with a strong adhesive.
    • Lift the battery from laptop.
    • Be careful not to bend the or puncture the battery, as that may cause a fire hazard.
  6. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, RAM or NVMe: stap 6, afbeelding 1 van 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, RAM or NVMe: stap 6, afbeelding 2 van 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, RAM or NVMe: stap 6, afbeelding 3 van 3
    • Once the battery is out, remove the screws at each standoff with a #00 Phillips screwdriver.
    • Remove the two additional screws under the fans.
    • Remove the screw securing the Wi-Fi card.
    • Disconnect and remove the wifi card from the motherboard.
    • Disconnect the additional cables connected to the motherboard.
    • Carefully lift the motherboard out of the computer.
    • The screen cable in the top left is short and restricts movement when removing the motherboard.
  7. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 7, afbeelding 1 van 2 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: stap 7, afbeelding 2 van 2
    • After flipping the motherboard over, locate the RAM slots.
    • Release each stick of RAM by carefully prying the metal clips away.
    • Remove M2 screw securing NVME drive.
    • Remove or replace NVME drive.
Conclusie
7 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 4,358
