Ga door naar hoofdinhoud
MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement
Wat je nodig hebt
  1. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 2
    • Using the Jimmy tool, pry the front cover off at the seam.
    • The Jimmy tool is the utensil in the first picture in the user's hand.
  2. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: stap 2, afbeelding 1 van 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 2 mm screws on the bottom and top corners of the screen using a Phillips #0 screwdriver.
  3. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Using the Jimmy, pry off the unscrewed LCD display.
    • Make sure the black adhesive is out of the way.
    • Don't pull the screen completely off, as the screen will still be attached.
  4. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: stap 4, afbeelding 1 van 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the ribbon cable by pulling on the bar code tab.
Conclusie
3 opmerkingen
Hey Jordan, when reassembling the front cover (which in my case, a GP63 Leopard 8RE, is glued at the bottom) what type of glue should be used? Thanks
Jaime Blasco - Antwoord
Hi Jaime, two part expoxy (Alraldite) glue should work, otherwise 3M double-sided adhesive tape would work as well.
Jordan Buck -
Hi Jordan,
If the screen is damaged due to the cover itself being bent, do you have any advice?
Thanks
Ainsley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 23
Altijd: 1,318
