Ga door naar hoofdinhoud
MSI GP62MVR 6RF Leopard Pro Fans Replacement
Wat je nodig hebt
  1. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 2, afbeelding 1 van 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 2, afbeelding 2 van 2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: stap 4, afbeelding 1 van 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: stap 4, afbeelding 2 van 2
    • Remove the eight 4.5 mm screws that hold the heat sink to the motherboard with a Phillips #0 screwdriver.
    • Remove the four 4.5 mm screws holding the fan in place also using a Phillips #0 screwdriver.
    • Watch for the screw hidden under the wires highlighted in the second picture.
  5. MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 5, afbeelding 1 van 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 5, afbeelding 2 van 2
    • Disconnect both power cables for the fans.
    • Make sure to pinch the power cables. It may require a bit of force.
  6. MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 6, afbeelding 1 van 3 MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 6, afbeelding 2 van 3 MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 6, afbeelding 3 van 3
    • Using the Jimmy tool, remove the adhesive pads securing the fans to the board.
  7. MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 7, afbeelding 1 van 1
    • Remove the black adhesive.
  8. MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 8, afbeelding 1 van 1
    • Separate the heat sink from the tab on the side holding the fan in place.
  9. MSI GP62MVR 6RF Leopard Pro Fans Replacement: stap 9, afbeelding 1 van 1
    • Remove the three 3.5 mm screws on each fan holding the fan to the heat sink using a Phillips #0 screwdriver.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 1,207
