Ga door naar hoofdinhoud
MSI GE72 6QF Apache Pro SSD Replacement
Wat je nodig hebt
  1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: stap 1, afbeelding 1 van 2 MSI GE72 6QF Apache Pro SSD Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro SSD Replacement: stap 2, afbeelding 1 van 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro SSD Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro SSD Replacement: stap 4, afbeelding 1 van 2 MSI GE72 6QF Apache Pro SSD Replacement: stap 4, afbeelding 2 van 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro SSD Replacement: stap 5, afbeelding 1 van 2 MSI GE72 6QF Apache Pro SSD Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro SSD Replacement: stap 6, afbeelding 1 van 2 MSI GE72 6QF Apache Pro SSD Replacement: stap 6, afbeelding 2 van 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro SSD Replacement, SSD: stap 7, afbeelding 1 van 2 MSI GE72 6QF Apache Pro SSD Replacement, SSD: stap 7, afbeelding 2 van 2
    • Remove the single 5.5mm Phillips #1 screw attaching the SSD to the laptop.
  8. MSI GE72 6QF Apache Pro SSD Replacement: stap 8, afbeelding 1 van 2 MSI GE72 6QF Apache Pro SSD Replacement: stap 8, afbeelding 2 van 2
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Tanmay Kumar
458 Reputatie
4 handleidingen geschreven
Cal Poly, Team S14-G4, Banghart Spring 2017 Lid van Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 54
Altijd: 7,667
