Ga door naar hoofdinhoud
MSI GE72 6QF Apache Pro Hard Drive Replacement
Wat je nodig hebt
  1. MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 4, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 5, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 6, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: stap 7, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: stap 7, afbeelding 2 van 2
    • Remove the two 5.5mm screws with the Phillips #1 screwdriver.
  8. MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 8, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • Gently pull out the hard drive by wiggling it from right to left with your hands until it is removed.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Tanmay Kumar
458 Reputatie
4 handleidingen geschreven
Cal Poly, Team S14-G4, Banghart Spring 2017 Lid van Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
4 Leden
8 handleidingen geschreven
Één opmerking
I have just bought an MSI GP72VR Laptop and I screwed up and got the model with only one drive, an SSD. It nagged at me that I didn't get the one with 2 drives. Well I happen to build my own desktops and had a spare 500GB Mushkin SSD hanging around and decided, what the heck. I came here and couldn't find the exact model but this is identical for what I want. I have never seen an access like this where you have to remove 19 screws. So I am very happy that this is on iFixit. I removed the screws and couldn't get the bottom removed as shown, I had to go to the other side and then it came off fairly easily. I used a butter knife for the initial pry and that worked well. They had sent the disk holder with the computer so I had no problem installing and I just set it up in Disk Manager. Tanmay, thank you very much for the assist, it is appreciated.
adard745 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 7,746
