Ga door naar hoofdinhoud
MSI GE72 6QF Apache Pro Battery Replacement
Wat je nodig hebt
  1. MSI GE72 6QF Apache Pro Battery Replacement, Battery: stap 1, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Battery Replacement: stap 4, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Battery Replacement: stap 4, afbeelding 2 van 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Battery Replacement: stap 5, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Battery Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Battery Replacement: stap 6, afbeelding 1 van 2 MSI GE72 6QF Apache Pro Battery Replacement: stap 6, afbeelding 2 van 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Hovik Aklyan
233 Reputatie
1 Handleiding geschreven
4 opmerkingen
hi there, can we use the laptop without the battery attached? i mean using only the power adaptor straight through the electric plug
San - Antwoord
yes you can, might drop bit of performance if you have Hybrid power management on, buyed my laptop used its 4 years old now and was used 2 years, dont even checked used battery but removed it and using AC power, just after a while gonna need to replace vents…
also cooling is problem in summers, cut-off some plastics and using cooling pad (recommending with 3+ vents or good airflow)
Ivars Kemers -
Faut démonter TOUTES les vis ??? Je vais en perdre la moitié !
Bravo!! plus simple c’était pas possibles?
Dire qu’avant on avait une trappe coulissante d’acces (DELL) ..
Bruno R - Antwoord
Les PC portables MSI ne sont pas les pire à réparer, loin de là !
Par expérience, l’étape la plus délicate c’est d’arriver à enlever le capot car il est maintenu par des clips en plastique, après on a accès à pratiquement toutes les pièces sur ce modèle.
Aujourd’hui, les PC portables avec une trappe coulissante existent toujours, mais ils sont cher :)
Brendan -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 70
Altijd: 10,326
