Ga door naar hoofdinhoud
MSI GE62 Apache Pro 004 Speakers Replacement
Wat je nodig hebt
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: stap 2, afbeelding 1 van 2 MSI GE62 Apache Pro 004 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: stap 3, afbeelding 1 van 3 MSI GE62 Apache Pro 004 Speakers Replacement: stap 3, afbeelding 2 van 3 MSI GE62 Apache Pro 004 Speakers Replacement: stap 3, afbeelding 3 van 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: stap 4, afbeelding 1 van 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: stap 4, afbeelding 2 van 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: stap 4, afbeelding 3 van 3
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: stap 5, afbeelding 1 van 2 MSI GE62 Apache Pro 004 Speakers Replacement: stap 5, afbeelding 2 van 2
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Conclusie
Majid Al Hashmi
283 Reputatie
2 handleidingen geschreven
USF Tampa, Team S15-G5, Boczar Spring 2018 Lid van USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 1,494
