Ga door naar hoofdinhoud
MSI GE62 Apache Pro 004 Motherboard Replacement
Wat je nodig hebt
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: stap 2, afbeelding 1 van 2 MSI GE62 Apache Pro 004 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: stap 3, afbeelding 1 van 3 MSI GE62 Apache Pro 004 Motherboard Replacement: stap 3, afbeelding 2 van 3 MSI GE62 Apache Pro 004 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: stap 5, afbeelding 1 van 3 MSI GE62 Apache Pro 004 Motherboard Replacement: stap 5, afbeelding 2 van 3 MSI GE62 Apache Pro 004 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Conclusie
Alexander
86 Reputatie
1 Handleiding geschreven
USF Tampa, Team S15-G5, Boczar Spring 2018 Lid van USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Leden
5 handleidingen geschreven
Één opmerking
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 1,981
