Inleiding
Use this guide to upgrade or replace the solid-state drive in your MNT Reform. Reform uses a standard M.2 M-key socket for NVMe SSDs.
Before you perform this repair, if at all possible, back up your existing SSD.
Wat je nodig hebt
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Pull out the eight battery cells one by one, and set them aside safely.
Remove the single M2×4 pan head screw securing the SSD to the motherboard.
Lift the free end of the SSD up slightly and pull the SSD straight out of its M.2 socket on the motherboard.
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Één andere persoon heeft deze handleiding voltooid.
