Inleiding
Remove the transparent acrylic bottom plate to access most of your MNT Reform's internals.
Please be extra careful while and after opening the case of the device. MNT Reform uses eight 18650 batteries in series. When fully charged, these combine to a voltage of almost 29 volts, and the battery cells can easily deliver multiple amperes of current. Do not touch the metal pins of the battery holders with metal tools.
Wat je nodig hebt
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Één andere persoon heeft deze handleiding voltooid.
