Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Set-Top Box te repareren, gebruik onze reparatiehandleidingen.
  1. M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: stap 1, afbeelding 1 van 2 M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: stap 1, afbeelding 2 van 2
    • Remove 4 circle pads to access the 4 screws. Using a Philips head screwdriver, remove all 4.
  2. M8s OTT TV BOX  Teardown, Remove the bottom: stap 2, afbeelding 1 van 3 M8s OTT TV BOX  Teardown, Remove the bottom: stap 2, afbeelding 2 van 3 M8s OTT TV BOX  Teardown, Remove the bottom: stap 2, afbeelding 3 van 3
    • Remove the 4 circular pads, then using a Phillips screwdriver. Remove the 4 screws.
    • Using the metal spudger in the slits parallel to the Seal you will be able to separate the two piece's.
    • The piece should come off easily.
  3. M8s OTT TV BOX  Teardown: stap 3, afbeelding 1 van 3 M8s OTT TV BOX  Teardown: stap 3, afbeelding 2 van 3 M8s OTT TV BOX  Teardown: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • With a firm grip at the base of the cable pull up and away from board.
    • Locate the 4 screws, then using the Phillips screwdriver remove them.
    • Before the board can be removed, be sure to use your tweezers to untape the antenna from the housing.
    • The board should come out with ease.
  4. M8s OTT TV BOX  Teardown, Remove the LED board: stap 4, afbeelding 1 van 1
    • Using your Phillips head screwdriver remove the 2 screws that hold the unit to the housing
  5. M8s OTT TV BOX  Teardown, Remove the steel heat plate: stap 5, afbeelding 1 van 2 M8s OTT TV BOX  Teardown, Remove the steel heat plate: stap 5, afbeelding 2 van 2
    • With your Phillips head screwdriver, remove the 3 screws that hold it in place.
    • The device has been effectively disassembled.
    • Next I will guide you through a Detailed inspection of the main circuit board.
Austin Pollard
1.502 Reputatie
3 handleidingen geschreven
Reno Phone Repair Lid van Reno Phone Repair
Business
1 Lid
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 41
Altijd: 2,651
