Ga door naar hoofdinhoud
Lytro Camera First Generation Repair
Wat je nodig hebt
  1. Lytro Camera First Generation Repair, Lytro Camera First Generation Lens: stap 1, afbeelding 1 van 1
    • Pull the top off using your hands or the plastic opening tool.
  2. Lytro Camera First Generation Repair: stap 2, afbeelding 1 van 1
    • Unscrew the four screws(7.1cm) seen after taking the top off.
  3. Lytro Camera First Generation Repair: stap 3, afbeelding 1 van 1
    • Pry that silver piece off that you just took the four screws out of.
  4. Lytro Camera First Generation Repair: stap 4, afbeelding 1 van 1
    • Take the camera out of the red part. You should have 3 piece not including the top.
  5. Lytro Camera First Generation Repair: stap 5, afbeelding 1 van 1
    • Take the 3 screws(.5) out of the middle piece.
  6. Lytro Camera First Generation Repair: stap 6, afbeelding 1 van 1
    • After taking that off you will see the camera lens.
  7. Lytro Camera First Generation Repair: stap 7, afbeelding 1 van 1
    • Pry the piece hanging off with tweezers.
  8. Lytro Camera First Generation Repair: stap 8, afbeelding 1 van 1
    • Now you can unscrew the three screws(.5) seen releasing the camera lense from the camera.
  9. Lytro Camera First Generation Repair: stap 9, afbeelding 1 van 1
    • After that you can pull it off with the tweezers.
  10. Lytro Camera First Generation Repair: stap 10, afbeelding 1 van 1
    • Now that you have it off you can replace it and reverse the steps getting it back together.
Conclusie
Jeremiah Killam-Hull
109 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 476
