Ga door naar hoofdinhoud
Inleiding
This guide will provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector. In the process of this removal, it will be demonstrated how to clean the area of any dust and how to recycle the waste material- old light bulb.
Onderdelen
Geen onderdelen opgegeven.
  1. Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Unscrew the bulb screws on either side of the silver plate.
    • Unscrew the bulb screws on either side of the silver plate.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  5. Remove the light bulb from the projector by lifting the silver handle and pulling up.
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  6. Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  7. Use a new Q-tip to clean the fan blades and hole in which the light enters.
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  8. Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  9. Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  10. Dispose of the bulb by sending it to a recycling center.
    • Dispose of the bulb by sending it to a recycling center.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Desiree Benitez
128 Reputatie
1 Handleiding geschreven
Één commentaar
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 7
Altijd: 368
