Ga door naar hoofdinhoud
Optoma PRO360W Bulb Replacement
Wat je nodig hebt
  1. Optoma PRO360W Bulb Replacement, Unplug projector: stap 1, afbeelding 1 van 1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Optoma PRO360W Bulb Replacement: stap 2, afbeelding 1 van 1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Optoma PRO360W Bulb Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Optoma PRO360W Bulb Replacement: stap 4, afbeelding 1 van 1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Optoma PRO360W Bulb Replacement: stap 5, afbeelding 1 van 1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Optoma PRO360W Bulb Replacement: stap 6, afbeelding 1 van 1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Optoma PRO360W Bulb Replacement: stap 7, afbeelding 1 van 1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Optoma PRO360W Bulb Replacement: stap 8, afbeelding 1 van 1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Optoma PRO360W Bulb Replacement: stap 9, afbeelding 1 van 1
    • Dispose of the bulb by sending it to a recycling center.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Desiree Benitez
128 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 978
