Ga door naar hoofdinhoud
Lubricate General Electric Telephone 2-9710A Tuning Slider
Wat je nodig hebt
  1. Lubricate General Electric Telephone 2-9710A Tuning Slider, Phone Cord: stap 1, afbeelding 1 van 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Phone Cord: stap 1, afbeelding 2 van 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Lubricate General Electric Telephone 2-9710A Tuning Slider: stap 2, afbeelding 1 van 3 Lubricate General Electric Telephone 2-9710A Tuning Slider: stap 2, afbeelding 2 van 3 Lubricate General Electric Telephone 2-9710A Tuning Slider: stap 2, afbeelding 3 van 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Lubricate General Electric Telephone 2-9710A Tuning Slider, 9V Base Battery: stap 3, afbeelding 1 van 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, 9V Base Battery: stap 3, afbeelding 2 van 2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Volume Dial: stap 4, afbeelding 1 van 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Volume Dial: stap 4, afbeelding 2 van 2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. Lubricate General Electric Telephone 2-9710A Tuning Slider, Remove Screws on the Back: stap 5, afbeelding 1 van 1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. Lubricate General Electric Telephone 2-9710A Tuning Slider, Pry the Back Off: stap 6, afbeelding 1 van 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Pry the Back Off: stap 6, afbeelding 2 van 2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. Lubricate General Electric Telephone 2-9710A Tuning Slider, Lubricate General Electric Telephone 2-9710A Tuning Slider: stap 7, afbeelding 1 van 2 Lubricate General Electric Telephone 2-9710A Tuning Slider, Lubricate General Electric Telephone 2-9710A Tuning Slider: stap 7, afbeelding 2 van 2
    • Turn the tuning slider counterclockwise until the slider stops.
    • Apply lubricant to the slider rail.
    • Turn the tuning slider back and forth to distribute the lubricant.
    • Make sure the lubricant does not touch the circuit board. This can damage the circuit board.
Conclusie
Alles Rebel
72 Reputatie
3 handleidingen geschreven
Cal Poly, Team 16-59, Forte Fall 2012 Lid van Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 765
