Ga door naar hoofdinhoud
Logitech VX Nano Wireless Mouse Opening Procedure
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. Logitech VX Nano Wireless Mouse Opening Procedure, Remove batteries and nano receiver: stap 1, afbeelding 1 van 2 Logitech VX Nano Wireless Mouse Opening Procedure, Remove batteries and nano receiver: stap 1, afbeelding 2 van 2
    • Pull down on the battery release tab to remove the battery cover.
    • Remove battery cover.
  2. Logitech VX Nano Wireless Mouse Opening Procedure: stap 2, afbeelding 1 van 2 Logitech VX Nano Wireless Mouse Opening Procedure: stap 2, afbeelding 2 van 2
    • Pull the battery release tab away from the mouse so the two AA batteries come out.
  3. Logitech VX Nano Wireless Mouse Opening Procedure: stap 3, afbeelding 1 van 1
    • If the Nano Receiver is still in the mouse and not in your computer, remove it by pushing on the bright orange button. It should pop right out!
  4. Logitech VX Nano Wireless Mouse Opening Procedure, Open the mouse: stap 4, afbeelding 1 van 1
    • Find and remove the screws at the bottom of the battery compartment:
    • Two 6 mm Phillips #1 screws
    • When removing these two screws, it can be helpful to hold the plastic battery tab out of the way of your screwdriver.
  5. Logitech VX Nano Wireless Mouse Opening Procedure: stap 5, afbeelding 1 van 2 Logitech VX Nano Wireless Mouse Opening Procedure: stap 5, afbeelding 2 van 2
    • Use an opening pick to get underneath the corner of one of the adhesive skates.
    • As you start to remove the skate, make sure that the opening pick is underneath the entire adhesive pad—otherwise you run the risk of splitting the pad in half.
    • Continue to push the opening pick between the adhesive and the mouse case, slowly working the adhesive away from the case.
    • Repeat this same process for the two other skates.
    • Remove any old adhesive residue before applying new mouse skates.
  6. Logitech VX Nano Wireless Mouse Opening Procedure: stap 6, afbeelding 1 van 1
    • Remove the screws from the backside of the mouse:
    • Three 6 mm Phillips #1 screws
    • The top shell and bottom case are no longer connected. Keep the mouse steady so you can carefully remove the upper shell in the next step.
  7. Logitech VX Nano Wireless Mouse Opening Procedure: stap 7, afbeelding 1 van 2 Logitech VX Nano Wireless Mouse Opening Procedure: stap 7, afbeelding 2 van 2
    • Carefully separate the top plastic shell from the bottom case.
    • Remove the top shell.
Conclusie
Carsten Frauenheim
112.561 Reputatie
338 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.718 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 38
