Ga door naar hoofdinhoud
Logitech UE MegaBoom Motherboard Replacement
Wat je nodig hebt
  1. Logitech UE MegaBoom Motherboard Replacement, Outer Mesh: stap 1, afbeelding 1 van 3 Logitech UE MegaBoom Motherboard Replacement, Outer Mesh: stap 1, afbeelding 2 van 3 Logitech UE MegaBoom Motherboard Replacement, Outer Mesh: stap 1, afbeelding 3 van 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Motherboard Replacement: stap 2, afbeelding 1 van 3 Logitech UE MegaBoom Motherboard Replacement: stap 2, afbeelding 2 van 3 Logitech UE MegaBoom Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Motherboard Replacement: stap 3, afbeelding 1 van 2 Logitech UE MegaBoom Motherboard Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Motherboard Replacement, Battery: stap 4, afbeelding 1 van 1
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
  5. Logitech UE MegaBoom Motherboard Replacement, Speaker: stap 7, afbeelding 1 van 2 Logitech UE MegaBoom Motherboard Replacement, Speaker: stap 7, afbeelding 2 van 2
    • Insert a opening tool between the grating and the body of the speaker
    • Pry up allowing the tabs to pop out of place.
    • There will be an audible sound when the tabs have begun to pop out of place.
    • Apply the same procedure to the grating covering the second speaker.
  6. Logitech UE MegaBoom Motherboard Replacement: stap 8, afbeelding 1 van 2 Logitech UE MegaBoom Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use a opening tool to push the thin metal rod located on the side of the speaker out.
    • Using needle nose pliers grasp the rod and pull the rod out of the speaker until fully removed.
    • Remove the remaining three rods.
    • One is located on the same side and two are located on the other speaker.
  7. Logitech UE MegaBoom Motherboard Replacement: stap 9, afbeelding 1 van 3 Logitech UE MegaBoom Motherboard Replacement: stap 9, afbeelding 2 van 3 Logitech UE MegaBoom Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Insert a opening tool between the speaker and the base
    • Pry up allowing the speaker tabs to pop out of place
    • Find and disconnect the wire from the motherboard by pulling in an upward motion.
    • Apply the same procedure to the second speaker.
  8. Logitech UE MegaBoom Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Grasp the mother board by the wider edge and pull towards yourself.
    • This should not require much force.
Conclusie
Oscar Ambriz
962 Reputatie
6 handleidingen geschreven
Cal Poly, Team S9-G2, Banghart Fall 2017 Lid van Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Leden
17 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 26
Altijd: 5,103
