Ga door naar hoofdinhoud
Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement
Wat je nodig hebt
  1. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: stap 1, afbeelding 1 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: stap 1, afbeelding 2 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: stap 1, afbeelding 3 van 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 2, afbeelding 1 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 2, afbeelding 2 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 2, afbeelding 3 van 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 3, afbeelding 1 van 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: stap 4, afbeelding 1 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: stap 4, afbeelding 2 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: stap 4, afbeelding 3 van 3
    • Apply an upward force with your thumbs to loosen the end cap.
    • Grasp the end cap and lift up to seperate it from the base.
  5. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 5, afbeelding 1 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 5, afbeelding 2 van 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 5, afbeelding 3 van 3
    Koop
    • Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
    • Push up on the rectangular connector from the bottom to loosen the circuit board.
  6. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 6, afbeelding 1 van 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: stap 6, afbeelding 2 van 2
    • Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
    • Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Oscar Ambriz
958 Reputatie
6 handleidingen geschreven
Cal Poly, Team S9-G2, Banghart Fall 2017 Lid van Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Leden
16 handleidingen geschreven
10 opmerkingen
How can I purchase this part being replaced thanks
Joseph Anderson - Antwoord
where can i get that part the whole board usb aux i need to replace due to water damage
jdw vlogs - Antwoord
I also need this part due to water damage. Where Do I order this entire motherboard at?
dersert6bunnie - Antwoord
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
Nick Johnston - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 115
Altijd: 11,588
