Ga door naar hoofdinhoud
Logitech UE MegaBoom 3 Power Button Control Board Replacement
Wat je nodig hebt
  1. Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: stap 1, afbeelding 1 van 2 Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: stap 1, afbeelding 2 van 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 2, afbeelding 1 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 2, afbeelding 2 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 2, afbeelding 3 van 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: stap 3, afbeelding 1 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: stap 3, afbeelding 2 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: stap 3, afbeelding 3 van 3
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 4, afbeelding 1 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 4, afbeelding 2 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 4, afbeelding 3 van 3
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 5, afbeelding 1 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 5, afbeelding 2 van 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: stap 5, afbeelding 3 van 3
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
Conclusie
Anthony Miles
981 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 123
