Inleiding
This guide will show will allow you to see step by step how to take apart your UE Boom in order to get inside and change your speakers.
Wat je nodig hebt
Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
This part is not easy. The main risk is to broke the plastics clips.
Use a heat gun (or hair dryer on high) first around the edges before attempting to pry it open. There are six tabs: one directly in line with the charging port; one approx 3/4 inch to the left and right of that tab; one centered against the back of the volume control "panel", and one approx 3/4 inch to either side of that one. So when prying, try to insert your spudger in between those spacings in order to not push on the tabs directly.
Using a soldering iron, de-solder the two ends of the switch plate.
Great instructions here guys - just one comment from myself - underneath the plate there is glue holding it down as well as the solder joints. Be sure to heat it up slightly prior to lifting out otherwise the capacitors and other components get stuck in the glue.
bei mir sieht der blootooth-adapter anders aus. da muss ich nix löten, er ist klein und liegt nur in einer passenden mulde, aus der er herausgehoben und in die er wieder abgelegt werden kann. meine typbezeichnung ist S-00122.
Definitely start with the middle one, has 2 solder hinge points that took me a couple minutes to heat up, wiggle and finally lift up. One that side lifted, was much easier to go back to the edge hinge, heat up and just gently pull off.
It is importante to note that there are two large solder hinge points and for the midle to pin point. Easy to desoldering but not easy to soldering after battery replacement.
With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
Zuerst auf der Gegenseite zuerst den Deckel, dann die Hülle lösen. Erst am Ende die Seite mit dem Power Button.
Translation: First loosen the cover on the opposite side, then the cover. Only at the end the page with the power button.
Dan -
A tips that could be help lot of us. i consider it what not easy to pry the sleeve off. But in fact there are many hole around the side that could be used to push through the holes, the plastic ring retainer.
At this point, you should have the case completely open and removed the battery from the motherboard.
18 andere personen hebben deze handleiding voltooid.
16 opmerkingen
thank you for this excellent tutorial. Would you have an idea where replacement speakers can be found online ?
Is it necessary to solder the bluetooth adapter because my speaker got dented and now it makes a weird popping sound when i play my music on high volume. i think the problem is that the metal frame is touching the speaker causing the popping sound when the speaker vibrates
my speaker have the same problem what should i do?
How many speakers are inside exactly, 2 or 4 ? I didn't understand if there are 2 per side or not...
I don't have sound on a side of my speaker and I don't now if this is normal (it is new)
There are 2 speakers and 2 passive resonators, the 2 on the top are speakers while the 2 on the bottom are basically speakers without coils, they are just cones that rely on the pressure and vibration inside of the device generated by the real speakers on top to vibrate themselves and increase bass/low-end presence.
My speaker does the same sound wen i play my music loud
when i vigorously shake mine something inside shakes too what could be the problem
Where do I get replacement speakers from?ive only had mine for 8months but bought on duty free.
You should contact UE Support (http://www.ultimateears.com/en-us/suppor...). Your product should have 2 years warranty.
Alternatively… STEP 1 buy a new speaker.
Where can I buy this UE replacement speakers? I have 2 broken.
Where can I purchase speakers for use boom
My speaker fell on the floor: the battery is 100% and the speaker is ON, speaker is connected to my iPhone via Bluetooth (or via cable), I and can increase and decrease the volume (I'll checked in the app) BUT I have no music sound whatsoever? The speaker has now been completely taken apart, but all cables appear to be connected and nothing looks wrong on the printing board: what could be the problem?
If you get a tone when you hit the volume limit, the issue is upstream of the speaker it’s self and the speakers Amp. This gets into the the DAC logic and the Analog/Bluetooth connection logic. Basically, the logic board has an issue.
Dan -
