Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
To remove the plastic cover. You want to use the plastic opener and starting with corners.
Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
Remove eight 10.5 mm Phillips #1 screws from the cover.
Insert a metal spurger at the corner to help loosen the cover.
Starting with corners, lift up the cover slowly and carefully.
Identity the speaker cover, and remove four 4.5 mm Phillips #1 screws.
Lift up the cone. It should be removed very easily by hand.
Remove four 5.2mm Phillips #1 screws that are securing the circuit board.
Unplug the connecting wire from the circuit board. Carefully lift up the circuit board.
Same as step 3, remove four 4.5 mm Phillips #1 screws from the speaker cone.
