Inleiding
1- Remove the cover where you replace the battery.
2 - Below each battery, there is a screw that you remove with a small Philips screwdriver.
3 - At the top of the back part of the mouse there are two rubber finishes that you remove (it has an adhesive) and there you will find the screws that hold the top.
4 - It gets loose immediately, please be careful with the wire that connects one part to another, please disconnect this wire.
Wat je nodig hebt
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
