Ga door naar hoofdinhoud
Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning
Wat je nodig hebt
  1. Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning, Scroll wheel: stap 1, afbeelding 1 van 3 Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning, Scroll wheel: stap 1, afbeelding 2 van 3 Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning, Scroll wheel: stap 1, afbeelding 3 van 3
    • Use a thin blade to peel up the corners and remove the mouse feet. They re-adhere very well, so be careful to not damage them or get the sticky side dirty.
    • Unscrew the three screws that are now visible.
    • Gently pull apart the top and bottom halves of the mouse. They will be connected by a wire.
  2. Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 2, afbeelding 1 van 3 Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 2, afbeelding 2 van 3 Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 2, afbeelding 3 van 3
    • Slide the scroll wheel up and out of the housing.
    • Take the scroll wheel assembly apart and clean off any obvious debris.
    • Look through each of the holes in the scroll wheel to check for debris that could be obstructing the optical sensor. Use a needle to clean out any obstructions.
  3. Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 3, afbeelding 1 van 2 Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 3, afbeelding 2 van 2
    • Optional: If there is any material near the base of the mouse, under the scroll wheel, the sensor chip can be unscrewed and removed.
    • Use a gas duster to remove any remaining dust from inside the mouse.
  4. Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 4, afbeelding 1 van 3 Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 4, afbeelding 2 van 3 Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 4, afbeelding 3 van 3
    • Reassemble the scroll wheel.
    • If done correctly, the wheel should click while scrolling. The wheel should not spin freely.
    • Optional: Before reinserting the scroll wheel peg, apply lubricant if needed.
  5. Logitech MX518 Gaming Mouse Scroll wheel replacement for cleaning: stap 5, afbeelding 1 van 1
    • Slide the scroll wheel back down into its housing.
    • Make sure that the spring is aligned correctly.
    • Place the top half of the mouse back on to the bottom half and screw the mouse together.
    • Stick the mouse feet back on to their respective locations.
Conclusie
Plug the mouse back in to a computer and test for responsiveness. If the mouse wheel is clean but still does not function, contact Logitech support.
49 andere personen hebben deze handleiding voltooid.
Ben
1.362 Reputatie
1 Handleiding geschreven
32 opmerkingen
It worked! Thank you so much!
laurieannismorgan - Antwoord
got my scroll wheel back from just being intermittent. nice guide for the best mouse ever made. All hail the mighty MX518, shotter of many heads, destroyer of Skyrim, Diablo I,II,III and lately bearer of the Witchers mighty blades. HAIL HAIL HAIL MX518!!!
aer0squid - Antwoord
My mouse went from scrolling just fine to nothing overnight. This helped a lot, but sadly its still not 100%. :(
Jimmy Kupczak -
Worked like a charm. Thanks. I really like this mouse and didn't want to have to get used to another one.
Charles Mercer - Antwoord
Fantastic!!! I've been really reluctant to replace my MX510 mouse -- your teardown of this one (which the internals appear to be identical anyway) was perfect!
My mouse is running like brand new again!
Raymond Morgan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 247
Altijd: 64,873
