Ga door naar hoofdinhoud
Logitech M515 (Couch) Mouse
Wat je nodig hebt
  1. Logitech M515 (Couch) Mouse, Removing the outer shell: stap 1, afbeelding 1 van 1
    • Remove the battery hatch and batteries.
  2. Logitech M515 (Couch) Mouse: stap 2, afbeelding 1 van 1
    • Remove the single Phillips screw located between the battery sockets.
    I used this guide to open my Logitech M-RCQ142 (that looks almost the same). Logitech changed the one screw-system to four screws located in the same place, so this guide worked perfect. Thanks for sharing!
    WillemPirquin - Antwoord
  3. Logitech M515 (Couch) Mouse: stap 3, afbeelding 1 van 1
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    doesn't go deep enough. need to fix right switch. part numbers are required.
    Lewayne Gragert - Antwoord
    I doubt you can get parts for this, it's not a high ticket item.
    Anna Sweetnam - Antwoord
Conclusie
4 andere personen hebben deze handleiding voltooid.
Anna Sweetnam
232 Reputatie
1 Handleiding geschreven
4 opmerkingen
I got to step 3. where is step 4?
hawaii50 - Antwoord
What are you trying to do? All of the innards are available once step 3 is complete.
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Antwoord
M545 works similarly btw
Adri Idzwan Mansor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 4,920
