Ga door naar hoofdinhoud
Logitech M515 (Couch) Mouse
Wat je nodig hebt
  1. Logitech M515 (Couch) Mouse, Removing the outer shell: stap 1, afbeelding 1 van 1
    • Remove the battery hatch and batteries.
  2. Logitech M515 (Couch) Mouse: stap 2, afbeelding 1 van 1
    • Remove the single Phillips screw located between the battery sockets.
  3. Logitech M515 (Couch) Mouse: stap 3, afbeelding 1 van 1
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Anna Sweetnam
232 Reputatie
1 Handleiding geschreven
4 opmerkingen
I got to step 3. where is step 4?
hawaii50 - Antwoord
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Antwoord
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Antwoord
M545 works similarly btw
Adri Idzwan Mansor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 4,918
