Wat je nodig hebt
The screws are hidden under the four rubber feet on the underside of the mouse.
Carefully peel away each foot and its layer of adhesive, putting them to the side to replace later.
Unscrew the four Phillips #0 screws hidden by the feet.
The top casing should now come loose with just a shake.
The scroll wheel is held in place by a plastic pin. Pull it sideways to remove it.
Grip the scroll wheel assembly by the transparent part and lift it out.
