Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Logitech M Series Mouse te repareren, gebruik onze reparatiehandleidingen.
  1. Logitech M235 Teardown, Logitech M235 Teardown: stap 1, afbeelding 1 van 1
    • Remove the battery and battery cover
  2. Logitech M235 Teardown: stap 2, afbeelding 1 van 2 Logitech M235 Teardown: stap 2, afbeelding 2 van 2
    • Remove the the two screws holding the cover.
    • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
  3. Logitech M235 Teardown: stap 3, afbeelding 1 van 1
    • Use a prying tool to split the mouse case apart.
  4. Logitech M235 Teardown: stap 4, afbeelding 1 van 1
    • The case should be easy to open and not require much force.
  5. Logitech M235 Teardown: stap 5, afbeelding 1 van 1
    • The PCB is only held by a few clips and can be easily removed.
  6. Logitech M235 Teardown: stap 6, afbeelding 1 van 1
    • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
  7. Logitech M235 Teardown: stap 7, afbeelding 1 van 1
    • Done!
Daniel
225 Reputatie
1 Handleiding geschreven
4Bits Repairs Lid van 4Bits Repairs
Business
1 Lid
2 handleidingen geschreven
8Gids Commentaar
Great work. Hope to see some more of your work
Mustafa karu - Antwoord
thank you..this helped me a looot
Sharnav Kundu - Antwoord
My M325 has NO SCREWS!!! Now what???
christcansaveyou - Antwoord
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - Antwoord
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 160
Altijd: 22,952
