Ga door naar hoofdinhoud
Logitech K750 Keyboard Battery Replacement
Wat je nodig hebt
  1. Logitech K750 Keyboard Battery Replacement, Turn off the keyboard: stap 1, afbeelding 1 van 1
    • Before you begin, flip the keyboard's power switch into the OFF position.
  2. Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: stap 2, afbeelding 1 van 2 Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: stap 2, afbeelding 2 van 2
    • Flip the entire keyboard over, keys facing down.
  3. Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: stap 3, afbeelding 1 van 3 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: stap 3, afbeelding 2 van 3 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: stap 3, afbeelding 3 van 3
    • The ML2032 rechargeable coin cell battery is located in a tray at the back edge of the keyboard.
    • Insert the flat end of a spudger into the gap between the battery tray and the top surface of the keyboard.
    • Pivot the spudger down, towards the top of the keyboard, to begin to pry the tray out of its cavity.
  4. Logitech K750 Keyboard Battery Replacement, Remove the battery tray: stap 4, afbeelding 1 van 3 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: stap 4, afbeelding 2 van 3 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: stap 4, afbeelding 3 van 3
    • Use the flat end of the spudger to push the battery tray out and away from the keyboard.
    • The tray is held in by small "ears" and may take a significant amount of force to dislodge.
    • Remove the battery tray.
    • During reassembly, firmly push the battery tray into its slot until it clicks into place.
  5. Logitech K750 Keyboard Battery Replacement, Remove the battery: stap 5, afbeelding 1 van 3 Logitech K750 Keyboard Battery Replacement, Remove the battery: stap 5, afbeelding 2 van 3 Logitech K750 Keyboard Battery Replacement, Remove the battery: stap 5, afbeelding 3 van 3
    • Push the battery out of the tray to remove it.
    • Note the battery orientation—it can only go in one way. Set the battery into the tray with side with the text and the "+" sign facing down.
    • Use only a rechargeable ML2032 coin cell battery as a replacement. Although it's the same size and shape as the more common CR2032, CR2032s are not rechargeable.
Conclusie
209 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
113.137 Reputatie
338 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.767 handleidingen geschreven
94 opmerkingen
Thank you. Worked perfectly. Gained trust in this site. Lost respect for Logitech.
henry - Antwoord
My sentiments, exactly!
Melinda Mcvay -
There a better way to open it
put the knife or better a screwdriver on the other side (keys upside); worked for me without damage the keyboard :D
yannick NR - Antwoord
Thank You! That did work much better!
Matt Anderson -
Here is an even better method.
You can also totally prevent damage by finding a laminated biz card and cutting it into 2 one inch strips and inserting both of them into the slot on the top side (solar side) of the battery compartment.
Then get your tool ( I like small pointed scissors) and pry it out between the cards.
Very easy!
David Powers -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 38
Afgelopen 7 dagen: 258
Afgelopen 30 dagen: 1,175
Altijd: 252,525
