Inleiding
If you need to open up your Logitech K480, follow this guide.
Wat je nodig hebt
Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
Slide a blue pick in to keep the pieces apart while you work on other areas.
Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
Één andere persoon heeft deze handleiding voltooid.
