Inleiding
If the internal power adapter for your Logitech Harmony Touch Universal Remote, (Model Number 915-000279 or 915-000198) stops working, (won't charge, etc.), this guide will show you how to replace it.
The power adapter helps to narrow down the amount of voltage going into the product from its electrical source.
Before beginning, make sure to check the port for any debris. If any removable debris exists, use a small dust blower to remove it.
Wat je nodig hebt
Open the latch that assesses the charging port.
Remove the black sticker and remove the screw with the indicated screwdriver.
