Ga door naar hoofdinhoud
Logitech Harmony Touch Motherboard Replacement
Wat je nodig hebt
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Open the latch that accesses the charging port
    • Remove the black sticker and remove the screw with the indicated screwdriver
    • Take the plastic opening tool and run it down the side of the remote to pop the case open
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out
    • Detach the white clamp to partially disconnect the case from the motherboard
  2. Logitech Harmony Touch Motherboard Replacement: stap 2, afbeelding 1 van 3 Logitech Harmony Touch Motherboard Replacement: stap 2, afbeelding 2 van 3 Logitech Harmony Touch Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Peel back thin yellow plastic film and detach the clip found underneath
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver
    • Next, carefully remove the motherboard from the top piece of the case
    • The motherboard is connected to the bottom part of the case
    • You should now be able to access all of the buttons and remove them from the case
Conclusie
Lennox Saliva-Rojas
281 Reputatie
2 handleidingen geschreven
USF Tampa, Team S4-G2, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 726
