Ga door naar hoofdinhoud
Logitech Harmony Smart Control Remote Buttons Replacement
Wat je nodig hebt
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: stap 1, afbeelding 1 van 2 Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: stap 1, afbeelding 2 van 2
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
  2. Logitech Harmony Smart Control Remote Buttons Replacement: stap 2, afbeelding 1 van 2 Logitech Harmony Smart Control Remote Buttons Replacement: stap 2, afbeelding 2 van 2
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
  3. Logitech Harmony Smart Control Remote Buttons Replacement: stap 3, afbeelding 1 van 2 Logitech Harmony Smart Control Remote Buttons Replacement: stap 3, afbeelding 2 van 2
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
  4. Logitech Harmony Smart Control Remote Buttons Replacement: stap 4, afbeelding 1 van 3 Logitech Harmony Smart Control Remote Buttons Replacement: stap 4, afbeelding 2 van 3 Logitech Harmony Smart Control Remote Buttons Replacement: stap 4, afbeelding 3 van 3
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
  5. Logitech Harmony Smart Control Remote Buttons Replacement: stap 5, afbeelding 1 van 1
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
Conclusie
Josh Hendricks
464 Reputatie
4 handleidingen geschreven
IUPUI, Team 3-2, Harley Fall 2015 Lid van IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Leden
5 handleidingen geschreven
9Gids Commentaar
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - Antwoord
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde -
Where do you purchase button replacements?
Steve Lutes - Antwoord
Flavio Campos - Antwoord
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 44
Altijd: 6,241
