Inleiding
This is a guide to do a partial disassembly of the left-side of a Logitech G935. This is my daily-use headset, so I went as far as I was comfortable with knowing I could safely disassemble and reassemble without breaking tabs, glue, wires, or anything else like that.
After disassembly, reassembly is easy reversing these steps.
Remove the ear cup. It is slightly elastic and may be gently stretched off, starting at one point and gently working around the perimeter. A spudger may help in both removal, and especially re-installation.
Remove the 6 Phillips #0 screws retaining the top section.
Gently pull off the section you just unscrewed. Flipping it upside-down off to the side is a good bet.
Note there is a thin cable soldered to both halves. Be very gentle with this, as I suspect repair will be near-impossible. (It's surface-mounted on the PCB, and sealed inside the driver.)
Remove the 2 screws holding the rear plastic facade that retains the buttons and volume wheel.
Detach the ribbon cable from the daughterboard.
Remove the ribbon cable connecting the daughterboard to the mainboard.
Open the microphone to expose a hidden screw
Remove the screw retaining the front plastic facade.
The microphone will now come out. Take care as it's attached to the daughterboard via a small fragile soldered cable.
With the microphone out, remove the screw retaining the daughterboard.
Gently pry the daughterboard out. Prying from the curved section towards the screw (as the yellow arrow points) worked well for me.
Take care once the daughterboard is free, as it is still connected to the mainboard via soldered wires.
11 andere personen hebben deze handleiding voltooid.
Één opmerking
Thanks! It helped a lot. Mine was having a problem with the power on slider, I sprayed a little bit of contact cleaner and a little bit of rubbing with a soft brush, it's working like new now!
