Ga door naar hoofdinhoud
Logitech G920 Driving Force Motor Motherboard Replacement
Wat je nodig hebt
  1. Logitech G920 Driving Force Motor Motherboard Replacement, Motor Motherboard: stap 1, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force Motor Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force Motor Motherboard Replacement: stap 3, afbeelding 1 van 2 Logitech G920 Driving Force Motor Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force Motor Motherboard Replacement: stap 4, afbeelding 1 van 2 Logitech G920 Driving Force Motor Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force Motor Motherboard Replacement: stap 5, afbeelding 1 van 2 Logitech G920 Driving Force Motor Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 13.5 mm screws with a Phillips #0 screwdriver.
  6. Logitech G920 Driving Force Motor Motherboard Replacement: stap 6, afbeelding 1 van 2 Logitech G920 Driving Force Motor Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the pedals from both sides of the wheel base.
  7. Logitech G920 Driving Force Motor Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the three 36 mm screws with a Phillips #2 screwdriver.
  8. Logitech G920 Driving Force Motor Motherboard Replacement: stap 8, afbeelding 1 van 3 Logitech G920 Driving Force Motor Motherboard Replacement: stap 8, afbeelding 2 van 3 Logitech G920 Driving Force Motor Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Remove the wheel base from the motor box.
  9. Logitech G920 Driving Force Motor Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Flip the motor box over.
    • Remove the twelve 12.2 mm screws with a Phillips #0 screwdriver.
    • Remove the two 11.5 mm screws with a Phillips #0 screwdriver.
  10. Logitech G920 Driving Force Motor Motherboard Replacement: stap 10, afbeelding 1 van 2 Logitech G920 Driving Force Motor Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Flip over the motor box once more.
    • Remove the motor box cover.
  11. Logitech G920 Driving Force Motor Motherboard Replacement: stap 11, afbeelding 1 van 3 Logitech G920 Driving Force Motor Motherboard Replacement: stap 11, afbeelding 2 van 3 Logitech G920 Driving Force Motor Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Remove the four 5 mm screws with a Phillips #0 screwdriver.
    • Detach the wires connected to the motherboard.
    • Remove the motherboard from the motor box.
Conclusie
Aiden Muse
477 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 277
Altijd: 1,042
