Ga door naar hoofdinhoud
Logitech G915 TKL G1-G8 Key Replacement
Wat je nodig hebt
  1. Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: stap 1, afbeelding 1 van 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: stap 1, afbeelding 2 van 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: stap 1, afbeelding 3 van 3
    • Remove all the keycaps.
    • While it can be done barehanded, use of a flat tool to remove the keycaps or use a keycap puller is recommended to prevent damage.
  2. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the front: stap 2, afbeelding 1 van 1
    • Unscrew the front 2mm #00 Phillips screws found here.
  3. Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: stap 3, afbeelding 1 van 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: stap 3, afbeelding 2 van 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: stap 3, afbeelding 3 van 3
    • Remove the battery.
    • This will require the removal of the back sticker and unscrewing the two 2.5mm #0 Phillips screws circled.
  4. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the back: stap 4, afbeelding 1 van 1
    • Remove the remaining 2mm #00 Phillips back screws.
    • 3 screws are hidden under the rubber rests of the keyboard.
  5. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the motherboard: stap 5, afbeelding 1 van 1
    • Remove the 2mm #00 Phillips motherboard screws.
    • The G1-G8 keys are held in place by the motherboard itself. Once the motherboard is detached, they can be easily removed and replaced by hand.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon Souza
136 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-6, Petersen Spring 2023 Lid van UMass Dartmouth, Team 3-6, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G6
4 Leden
14 handleidingen geschreven
2 opmerkingen
I can't find anywhere to buy a replacement key, can you point to a place where this is available?.
Magnus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 203
Altijd: 2,459
