Ga door naar hoofdinhoud
Logitech G910 Lights Replacement
Wat je nodig hebt
  1. Logitech G910 Lights Replacement, Lights: stap 1, afbeelding 1 van 1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: stap 2, afbeelding 1 van 1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: stap 3, afbeelding 1 van 1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: stap 4, afbeelding 1 van 2 Logitech G910 Lights Replacement, Lift the film: stap 4, afbeelding 2 van 2
    • Gently lift up the plastic film in the top right corner.
Conclusie
5 andere personen hebben deze handleiding voltooid.
4Gids Commentaar
So what do I do after I take apart my keyboard?
CuddlyZebesian - Antwoord Deel
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola - Deel
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire - Deel
This is just a guide to open the keyboard, not a light replacement. Finish or rename the guide.
Wesley Mason - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 109
Altijd: 7,967
