Ga door naar hoofdinhoud
Logitech G602 Side Motherboard Replacement
Wat je nodig hebt
  1. Logitech G602 Side Motherboard Replacement, Side Motherboard: stap 1, afbeelding 1 van 1
    • Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
  2. Logitech G602 Side Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
  3. Logitech G602 Side Motherboard Replacement: stap 3, afbeelding 1 van 2 Logitech G602 Side Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the blue spudger to prop open the bottom battery port.
    • Remove the AA batteries.
  4. Logitech G602 Side Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  5. Logitech G602 Side Motherboard Replacement: stap 5, afbeelding 1 van 2 Logitech G602 Side Motherboard Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to grip and pull the white ribbon cable from the motherboard.
  6. Logitech G602 Side Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
  7. Logitech G602 Side Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
    • We used a set of pliers and a Phillips #00 screw bit because the screwdriver couldn't fit into the side of the device.
  8. Logitech G602 Side Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use a black spudger and your fingers to loosen and remove the side motherboard.
Conclusie
2 opmerkingen
Is the white momentary switch the middle click button?
I have a couple of G602's that have failing middle click buttons, and if it's the momentary switch, it looks like an easy fix.
Agit - Antwoord
G5 Button was sticking. Followed guide, I did not need spudger. Brushed board and buttons with toothbrush and alcohol. Button works now, thanks!
P Kemp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 52
Altijd: 4,203
