Ga door naar hoofdinhoud
Logitech G602 Side Motherboard Replacement
Wat je nodig hebt
  1. Logitech G602 Side Motherboard Replacement, Side Motherboard: stap 1, afbeelding 1 van 1
    • Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
  2. Logitech G602 Side Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
  3. Logitech G602 Side Motherboard Replacement: stap 3, afbeelding 1 van 2 Logitech G602 Side Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the blue spudger to prop open the bottom battery port.
    • Remove the AA batteries.
  4. Logitech G602 Side Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  5. Logitech G602 Side Motherboard Replacement: stap 5, afbeelding 1 van 2 Logitech G602 Side Motherboard Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to grip and pull the white ribbon cable from the motherboard.
  6. Logitech G602 Side Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
  7. Logitech G602 Side Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
    • We used a set of pliers and a Phillips #00 screw bit because the screwdriver couldn't fit into the side of the device.
  8. Logitech G602 Side Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use a black spudger and your fingers to loosen and remove the side motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Is the white momentary switch the middle click button?
I have a couple of G602's that have failing middle click buttons, and if it's the momentary switch, it looks like an easy fix.
Agit - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 38
Altijd: 3,773
