Ga door naar hoofdinhoud
Logitech G602 Scroll Wheel Replacement
Wat je nodig hebt
  1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: stap 1, afbeelding 1 van 1
    • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
  2. Logitech G602 Scroll Wheel Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
  3. Logitech G602 Scroll Wheel Replacement: stap 3, afbeelding 1 van 2 Logitech G602 Scroll Wheel Replacement: stap 3, afbeelding 2 van 2
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  4. Logitech G602 Scroll Wheel Replacement: stap 4, afbeelding 1 van 1
    • Use the black spudger to move the tip of the metal spring off of the wheel.
    • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
Conclusie
9 andere personen hebben deze handleiding voltooid.
4 opmerkingen
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - Antwoord
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - Antwoord
"Logitech G602 Scroll Wheel Replacement" - completely misleading title. Thanks for wasting people's time.
Myshka - Antwoord
Merci pour les recommandations. Elles m'ont permis de voir qu'il y avait un fil dessoudé. ça m'aurait bien gêné d'en racheter une autre.
Didielus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 91
Altijd: 9,055
