Ga door naar hoofdinhoud
Logitech G400s Scroll Wheel Replacement
Wat je nodig hebt
  1. Logitech G400s Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 1
    • Use a flathead screwdriver or your fingernail to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Scroll Wheel Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Scroll Wheel Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Scroll Wheel Replacement: stap 4, afbeelding 1 van 1
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Scroll Wheel Replacement: stap 5, afbeelding 1 van 1
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Scroll Wheel Replacement: stap 6, afbeelding 1 van 1
    • Simply lift the scroll wheel out of the compartment it sits in. It can then be cleaned or replaced as desired.
Conclusie
Max Evans
403 Reputatie
3 handleidingen geschreven
USF Tampa, Team 16-7, Eyestone Fall 2016 Lid van USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Lid
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 3,752
