Ga door naar hoofdinhoud
Logitech G305 Scroll Wheel Replacement
Wat je nodig hebt
  1. Logitech G305 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 2 Logitech G305 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
  2. Logitech G305 Scroll Wheel Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the four bottom case screws.
    • Caution, do not strip the head of the screws. These are not easily replaceable.
  3. Logitech G305 Scroll Wheel Replacement: stap 3, afbeelding 1 van 1
    • Remove the palm cover by simply sliding downwards. Remove the battery and the bluetooth usb.
    • Using a flat head screwdriver 1.5mm to not pry but to adjust the connector. By doing this it will allow you to open the inside.
    • Use caution when raising the outer shell—wires are still connected inside.
  4. Logitech G305 Scroll Wheel Replacement: stap 4, afbeelding 1 van 2 Logitech G305 Scroll Wheel Replacement: stap 4, afbeelding 2 van 2
    • Using the flathead screwdriver 1.5mm you can undo the clip holding the wiring in place.
  5. Logitech G305 Scroll Wheel Replacement: stap 5, afbeelding 1 van 1
    • There is a metal spring that holds one side of the scroll wheel, remove the metal spring using a flathead screwdriver 1.5mm and lifting the scroll wheel.
  6. Logitech G305 Scroll Wheel Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips screw driver #00 to remove the four screws.
    • Be careful to not strip the screws, these can't be found at your local hardware store.
  7. Logitech G305 Scroll Wheel Replacement: stap 7, afbeelding 1 van 3 Logitech G305 Scroll Wheel Replacement: stap 7, afbeelding 2 van 3 Logitech G305 Scroll Wheel Replacement: stap 7, afbeelding 3 van 3
    • Using the Flathead screwdriver 1.5mm, disconnect the clip for the green and blue wire.
    • Remove the motherboard out of the casing.
    • The mouse wheel can only come out one way. Slide to the right to release mouse wheel.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Één opmerking
Should you encounter issues with a malfunctioning scroll wheel, consider cleaning it using a can of compressed air and then applying a small amount of PTFE-based multi-use synthetic oil to the scroll wheel housing.
tomzo88 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 144
Afgelopen 30 dagen: 582
Altijd: 21,672
