Ga door naar hoofdinhoud
Logitech G1 Optical Mouse Scroll Wheel Replacement
Wat je nodig hebt
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 1
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 2, afbeelding 1 van 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 2, afbeelding 2 van 2
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 3, afbeelding 1 van 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 3, afbeelding 2 van 2
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 4, afbeelding 1 van 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 4, afbeelding 2 van 2
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 5, afbeelding 1 van 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 6, afbeelding 1 van 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 6, afbeelding 2 van 2
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 7, afbeelding 1 van 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 7, afbeelding 2 van 2
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: stap 8, afbeelding 1 van 1
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
wooseok yang
331 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 55
Altijd: 1,563
