Ga door naar hoofdinhoud
Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement
Wat je nodig hebt
  1. Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement, Logitech G X56 HOTAS Joystick Opening Joystick Disassembly: stap 1, afbeelding 1 van 2 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement, Logitech G X56 HOTAS Joystick Opening Joystick Disassembly: stap 1, afbeelding 2 van 2
    • Turn the locking bezel counterclockwise, then remove the joystick from the joystick base.
  2. Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 2, afbeelding 1 van 3 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 2, afbeelding 2 van 3 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 2, afbeelding 3 van 3
    • Remove the five 11.7 mm-long Phillips #0 screws that secure the case.
  3. Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 3, afbeelding 1 van 2 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 3, afbeelding 2 van 2
    • Pull the joystick casing apart to reveal the internal components.
    • The casing will need a little force to split open.
    • Take care not to damage or strain the connected cable.
  4. Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 4, afbeelding 1 van 2 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 4, afbeelding 2 van 2
    • Grip and pull the white connector directly out of its socket.
    • The connector is fragile. If removed forcefully, it may affect the PCB performance.
  5. Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 5, afbeelding 1 van 2 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 5, afbeelding 2 van 2
    • Refer to the left or right side for replacement guides of other parts (left, then right side in order).
  6. Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement, Thumb HATs Cover: stap 6, afbeelding 1 van 3 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement, Thumb HATs Cover: stap 6, afbeelding 2 van 3 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement, Thumb HATs Cover: stap 6, afbeelding 3 van 3
    • Remove the two Phillips #0 6.9 mm-long screws that secure the HAT switch PCB.
  7. Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 7, afbeelding 1 van 2 Logitech G X56 HOTAS Joystick Thumb HATs (Witch and Castle) Cover Replacement: stap 7, afbeelding 2 van 2
    • Turn the joystick and remove the HAT cover.
Conclusie
Hannah Henderson
555 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 39
Altijd: 58
