Ga door naar hoofdinhoud
Logitech G Pro X Superlight Scroll Wheel Replacement
Wat je nodig hebt
  1. Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Mouse skates will be damaged during this process. Having a new pair of mouse skates is STRONGLY recommended.
    • Use tweezers to peel off the mouse skates on the underside of the mouse.
  2. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 2, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the six screws using a 1.6mm Phillips screwdriver on the top and bottom side of the mouse.
  3. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 3, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 3, afbeelding 2 van 2
    • Open the bottom shell with your hands.
    • Use caution, as wires are still intact.
    • The bottom shell should come off easily without applying any force.
  4. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 4, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wires and cables in contact with the sensor's motherboard.
    • Pull and shake evenly on the cable to make sure cables are not strained. Avoid pulling heavily.
  5. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 5, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 5, afbeelding 2 van 2
    • Take out the battery located at the back of the mouse.
    • Flipping it upside down helps when removing it.
  6. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 6, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 6, afbeelding 2 van 2
    • Remove four screws at the bottom part of the mouse with a 1.6mm screwdriver.
  7. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 7, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 7, afbeelding 2 van 2
    • Carefully take out the left and right mouse buttons.
  8. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 8, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 8, afbeelding 2 van 2
    • Remove the four screws attached to the scroll wheel.
  9. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 9, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 9, afbeelding 2 van 2
    • Apply pressure and shake evenly to remove the attached cable.
    • The scroll wheel comes off easily without using too much pressure.
    • Insert the new scroll wheel and line up against the sensor.
  10. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 10, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 10, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 10, afbeelding 3 van 3
    • Reattach the cable.
    • Refasten the four screws.
  11. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 11, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 11, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 11, afbeelding 3 van 3
    • Use a pair of tweezers to reinsert the four screws at the bottom half of the mouse and tighten with a screwdriver.
    • Attach the battery back on the bottom half of the mouse.
    • Reattach the two cables.
  12. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 12, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 12, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 12, afbeelding 3 van 3
    • Line up the bottom shell with the top shell and connect them together.
    • Reapply the four screws back onto the mouse.
  13. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 13, afbeelding 1 van 1
    • Put on your new mouse skates.
    • Apply pressure so that they stick to the mouse, leaving no air gap.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Zane
307 Reputatie
1 Handleiding geschreven
York University, Team M-9, Allen Summer 2023 Lid van York University, Team M-9, Allen Summer 2023
YORK-ALLEN-SU23SMG9
2 Leden
7 handleidingen geschreven
5 opmerkingen
Thanks for publishing this!
Do you replace only plastic part of wheel or plastic wheel + PCB?
Where do you order new wheel?
Andriy Legayev - Antwoord
https://ausmodshop.com/products/modded-l... pricy, but they have full replacement pcbs with all the parts installed for you so you
Daniel G -
I don't think the soft black part is separable for the original wheel. Ordered an 'original' (or mostly original 🙂) wheel at one famous giant Chinese marketplace for 6 USD, item id 1005006217893341 - couldn't find any difference
V S -
Thanks for the guide. Didn't need a new scroll wheel, but the disassembly guide was great.
Uber Beast - Antwoord
Thanks for the guide. Some steps are not necessary if your purpose is just to change the wheel
V S - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 100
Afgelopen 7 dagen: 604
Afgelopen 30 dagen: 3,105
Altijd: 54,763
