Inleiding
This guide is for replacing the LiPo Rechargeable Battery Logitech G Pro X Lightspeed. You battery may need to be replaced if your headset only turns on when plugged in or doesn't hold a long charge (factory spec is ~20 hours).
For your safety, discharge the battery below 25% before disassembling your device. Inspect batteries for physical and chemical damage. Battery should not be swollen to any extent. For non-OEM batteries, make sure your wires match with the original.
Wat je nodig hebt
Prepare headset. Remove mic and set power switch to off
Replacement part #533-000084. 1100mAh 3.7V 603450 Li-polymer battery
