Ga door naar hoofdinhoud
Logitech Dual Action disassembly
Wat je nodig hebt
  1. Logitech Dual Action disassembly, Taking out the screws: stap 1, afbeelding 1 van 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: stap 2, afbeelding 1 van 3 Logitech Dual Action disassembly, Opening the controller: stap 2, afbeelding 2 van 3 Logitech Dual Action disassembly, Opening the controller: stap 2, afbeelding 3 van 3
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: stap 3, afbeelding 1 van 1
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
Eindstreep
12 andere personen hebben deze handleiding voltooid.
Brian Neuman
1.097 Reputatie
3 handleidingen geschreven
USF Tampa, Team 7-4, Remmell Winter 2015 Lid van USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Leden
5 handleidingen geschreven
1Gids Commentaar
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 109
Altijd: 8,009
