Ga door naar hoofdinhoud
Logitech Dual Action Joystick Replacement
Wat je nodig hebt
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: stap 1, afbeelding 1 van 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: stap 2, afbeelding 1 van 3 Logitech Dual Action Joystick Replacement, Opening the controller: stap 2, afbeelding 2 van 3 Logitech Dual Action Joystick Replacement, Opening the controller: stap 2, afbeelding 3 van 3
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: stap 3, afbeelding 1 van 2 Logitech Dual Action Joystick Replacement, Replacing the joystick: stap 3, afbeelding 2 van 2
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
Eindstreep
24 andere personen hebben deze handleiding voltooid.
Brian Neuman
1.097 Reputatie
3 handleidingen geschreven
USF Tampa, Team 7-4, Remmell Winter 2015 Lid van USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Leden
5 handleidingen geschreven
5Gids Commentaar
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - Antwoord Deel
will the buttons still work if you put it all back?
Atsuku - Antwoord Deel
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - Antwoord Deel
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 229
Altijd: 13,500
