Ga door naar hoofdinhoud
Logitech Circle Speaker Replacement
Wat je nodig hebt
  1. Logitech Circle Speaker Replacement, Speaker: stap 1, afbeelding 1 van 2 Logitech Circle Speaker Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Speaker Replacement: stap 3, afbeelding 1 van 2 Logitech Circle Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Speaker Replacement: stap 4, afbeelding 1 van 2 Logitech Circle Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Speaker Replacement: stap 5, afbeelding 1 van 2 Logitech Circle Speaker Replacement: stap 5, afbeelding 2 van 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Speaker Replacement: stap 6, afbeelding 1 van 2 Logitech Circle Speaker Replacement: stap 6, afbeelding 2 van 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Speaker Replacement: stap 7, afbeelding 1 van 1
    • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
  8. Logitech Circle Speaker Replacement: stap 8, afbeelding 1 van 1
    • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
Conclusie
Emma Cochran
110 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 368
